I don't think VDJ has ever crashed since the 1.06 version. This program is simply amazing !!!!
geposted Fri 07 Nov 03 @ 3:23 am
lucky bastard, I had some crashes but I have to admit that it isn't that often anymore.
GnoedeL
GnoedeL
geposted Fri 07 Nov 03 @ 11:17 am
it crashes all the time for me.
i have a p4 1.7 , 224 ram, ddr video drive with sb live 5.1
now why does it crashes all the time for me ?
shall i try an re-download the kit ?
geposted Fri 07 Nov 03 @ 3:28 pm
cacanel:
224 ram... so 256Mo of DDR with 32Mo shared for your graphic card am I wrong?
You really need more ram! And as you have shared memory for your graphic card, is suppose you have a slow graphic card (certainly in a portable computer).
This might be your problem (Ram needs and slow Graphic card)
Be sure you have DirectX 9.0b installed on you PC and the latest graphic drivers too (take care with portable graphic drivers, they may be differents than desktop one)
Try also to change the memory setting on VDJ ("Max Load") to "none".
(I'm not sure this is the good words in the english version, look at the manual)
I hope this will help you.
geposted Fri 07 Nov 03 @ 3:48 pm
Cacanel:
The tascam skin is now a pack with three resolutions: the 1280x960 skin don't have the bug you talked about in the skin page. Hope you enjoy it.
www.link.ca/~rich/tascam__110703.zip
FRUiT94
FRUiT94
geposted Fri 07 Nov 03 @ 7:55 pm
I was a at a point where VDJ crashed every single time i loaded which was strange.
I simply did a full uninstall ... i even manually completely wiped out the entire VDJ directory. Re-installed and now everything has been amazing since.
Works great with XP setup as well as my windows 2000.
geposted Sat 08 Nov 03 @ 3:05 am
will a gf 2 mx 400 and another 128 ram do ?
geposted Sun 09 Nov 03 @ 3:57 am
no not at all!!!!
geposted Sun 09 Nov 03 @ 8:17 pm
take 1024ram and your shared grafic is no prob anymore
geposted Sun 09 Nov 03 @ 8:18 pm
well, if i remember well, the specs for Vdj were 128 ram and 1.2 gh
now why the ^&!%%^$@!( do i need 1024 ?
didn't i payed enough for VDj ?
or is Vdj for real powerful computers ?
geposted Mon 10 Nov 03 @ 3:45 pm
both of my computers run it pretty well with 512 of ram. However, my next upgrade will definately include more ram.
To your question, yes... Virtual is for stronger faster machines. 128 of ram will probably run it, but it will run MUCH MUCH smoother if you jump up to at least 512.
I had 256 when I first installed VirtualDJ, and imediately knew I needed more.
geposted Mon 10 Nov 03 @ 4:14 pm
you should no worry .. 1.07 its ready ,, and stability is better now ..thats lie tha main thing they say about virtual dj 1.07
geposted Mon 10 Nov 03 @ 10:58 pm
it used to crash like hell until i bumped up the buffer to 30mn
now testing v1.07
now testing v1.07
geposted Wed 12 Nov 03 @ 3:18 am
