I am trying to connect a Hercules inpulse 500 to virtual DJ 8.5.
When I try to install the driver I have downloaded off the Hercules website, I get an error message to do with files not being found in the C drive.
Has anyone experienced anything similar to this when trying to install drives? Thanks
geposted Sun 04 Oct 20 @ 5:24 pm
Hello folks.
In my case, The Hercules driver dont work corretly on VJD, because the pre-sound dont work, so i cant mix on the headfones.
I love this software, but, maybe i go to Serato...
geposted Sun 20 Dec 20 @ 1:44 am
Rogreki1 wrote :
Hello folks.
In my case, The Hercules driver dont work corretly on VJD, because the pre-sound dont work, so i cant mix on the headfones..
What Hercules model?
Probably you just set up the audio routing wrong in the sound settings ;-)
geposted Thu 24 Dec 20 @ 12:52 pm
Try download to desktop, run from there.
And alternatively, try if on right-click on the downloaded file, if you can choose "extract to..."
geposted Thu 24 Dec 20 @ 12:53 pm
