Hello there anybody know how to set the output level on Denon mc7000, I been broadcasting on periscope and always get a comment that volume is low , all I all ready have all my gain all way up, check Denon website said to press cue on deck 2 and turn load joystick to get access to set up output level, try several times I can't get to due, thanks for your help.
geposted Wed 07 Oct 20 @ 5:13 pm
Hallo, in der neusten Firmware 1.2 kannst du die Einstellung machen!
Hier die Anleitung:
http://cdn.inmusicbrands.com/denondj/MC7000/MC7000-Hardware-Settings-Mode-Specification-v1_4.pdf
Hier die Anleitung:
geposted Thu 08 Oct 20 @ 8:33 am
Hier die Anleitung:
Hier die Anleitung:
I all ready try it no luck cant get to the settings
geposted Fri 11 Dec 20 @ 1:07 am
Have you got the latest firmware installed?
Go here
Go here
geposted Fri 11 Dec 20 @ 8:37 am
It seems to be still a thing with the MC7000: recording/broadcast levels too low. Denon updated the driver and firmware for the MC8000 and MC7000 which can boost the USB level up to 20dB, but still it won't work on my MC7000. It seems to be not a VDJ issue, but the internal loopback in the driver. There are several threads going on about this on the VDJ and Denon forums.
geposted Mon 14 Dec 20 @ 12:40 am
I had a similar issue.. Remove the "input" Record - Denon DJ MC7000 form the audio settings... Once I removed this, volume was better.
geposted Mon 14 Dec 20 @ 7:18 pm
