Whenever I try to record a set it's saying that it's unable to open a file for writing.
What can I do to get around this?
Specs:
HP Probook 640 G4
Virtual 2020
Pioneer DDJ-SB3
Specs:
HP Probook 640 G4
Virtual 2020
Pioneer DDJ-SB3
geposted Fri 16 Oct 20 @ 3:37 pm
You're probably trying to record in a directory that's protected. Try recording to another location (directory/folder).
geposted Fri 16 Oct 20 @ 4:16 pm
I'm trying to record it to my Music file in my C Drive, literally a day ago I was able to record a set and save it to the same file but now it's not letting me do it. Id don't know how to get around it
geposted Fri 16 Oct 20 @ 5:13 pm
Fixed:
I tried to name my file with the "<" and ">" characters which the system does not like.
Changed the file name and allowed me to record again.
geposted Fri 16 Oct 20 @ 5:19 pm
I have the same issue how i fixed?
geposted Sun 11 Apr 21 @ 9:35 pm
click the ... button at end of the field to set record file name...
And pick a valid location and set a valid name
geposted Sun 11 Apr 21 @ 9:36 pm
Thanks, I had a / in my title. That caused the melee.
geposted Tue 05 Apr 22 @ 1:57 am
@Rune (DJ-In-Norway)
Atomix Productions
Just had the same issue. Lasted for 5 days. Clicking the box to the right worked. Thanks Bro!
Atomix Productions
geposted Sat 04 Feb 23 @ 7:30 pm
Change the Drive You Save The Files To And Create A New Folder On The ( New ) Drive
geposted Mon 18 Dec 23 @ 8:16 am
