Can the way forms on the Denon SC 5000 be expanded?
I want to zoom out.
I’ve tried changing the number in the setting for controllers with waveforms but it doesn’t seem to change anything .
I want to zoom out.
geposted Wed 28 Oct 20 @ 2:27 pm
You zoom in/out from VDJ, as you would with a skin on the computer.
I guess a couple of buttons could be added to the skin on the unit. What you can't do (yet, anyway) is use your fingers to zoom, the way they do when standalone.
geposted Wed 28 Oct 20 @ 3:27 pm
Zooming in/out on the skin has no effect on the unit.
Unless I’m missing something??
geposted Wed 28 Oct 20 @ 8:12 pm
On the SC 5000 screen?
Or you did in the software on the computer?
Dont have 5000 myself, but probably should try it on the 5000 screens
geposted Wed 28 Oct 20 @ 8:19 pm
Looking at this, there's a zoom icon (magnifying glass) on the left, under the key.
geposted Wed 28 Oct 20 @ 8:31 pm
The SC 5000 screen and I’ll check it out tonight Groovin, almost off from my day job 😝
geposted Wed 28 Oct 20 @ 8:44 pm
The magnify class button will for sure work, if touching the screens did not have support for such a touch gesture.
When activating the magnify class icon, you can use the Browse knob to adjust the zoom of the waveform.
See #13 here:
https://virtualdj.com/manuals/hardware/denon/sc5000/screen.html
See #13 here:
geposted Wed 28 Oct 20 @ 9:14 pm
You sir are correct 🤙🏾
Guess it’s time to read the manual fully 😝
Thanks for the help fellas!
geposted Wed 28 Oct 20 @ 10:23 pm
In case anyone was wondering the screen skins have been updated and its much better now, Thank you to whoever did it!!
geposted Sat 12 Dec 20 @ 2:56 pm
