Discussion about RMX-EchoMach3
geposted Thu 29 Oct 20 @ 8:19 pm
RMX-EchoMach3. After starting and stopping, the song being played comes out normally for a while, then becomes small for a while, and suddenly makes a loud sound and is out of control.
geposted Mon 04 Jan 21 @ 9:26 am
i just discovered this issue as well. it filters out a bit and then over modulates A LOT! Its a wonderful effect that I've been looking for awhile now, please get the bugs out. it is the answer between the issue of adding exf to everything or being able to add efx to say just vocals.
geposted Sun 07 Feb 21 @ 6:15 pm
If you start and stop RMX-EchoMach3 in the master effects, the song sound comes out normally for a certain period, then the song sound becomes quieter for a moment, and the song sound becomes very loud again and you can't control it.
geposted Mon 08 Feb 21 @ 12:39 pm
Alguien tiene idea de un VST o versión que sea igual o muy parecido a este? es una pena no poder usarlo por el fallo que habláis, el efecto es impresionante.
[Translation] Does anyone have an idea of a VST or version that is the same or very similar to this one? It's a shame not to be able to use it because of the error you mentioned, the effect is impressive.
geposted Fri 05 Apr 24 @ 9:28 pm
