Hi,
I have a Numark Mixtrack Platinum FX controller which for the most part works well with VDJ.
I would like to use the performance pads to beat jump and am hoping it is possible.
I don't use the fader cuts pads so was wondering how I could either remap these or could I map Shift + Fader cuts pads to allow the following:
Pad 1 - Forward 1 Beat
Pad 2 - Forward 2 Beats
Pad 3 - Forward 4 Beats
Pad 4 - Forward 8 Beats
Pad 5 - Back 1 Beat
Pad 6 - Back 2 Beats
Pad 7 - Back 4 Beats
Pad 8 - Back 8 Beats
I hope I've explained what I am trying to achieve.
Thanks in advance.
Pad 5 - Back 1 Beat
Thanks in advance.
geposted Sat 07 Nov 20 @ 1:43 pm
Just choose the Beat Jump pad page..
You can do this temporary on the fly (in skin, at the drop down above pads),
or assign beat jump to one of the 4 buttons above the performance pads if you assign it to them
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#controller
geposted Sat 07 Nov 20 @ 2:07 pm
