Audio track splitting without air gaps
geposted Tue 10 Nov 20 @ 8:55 pm
I suppose you mean when you record a mix then...
Simply go to settings, and then Options. Set recordAutoSplit to "yes"
geposted Tue 10 Nov 20 @ 9:16 pm
when using record it would be great if it saved the tag name of the track
geposted Sat 28 Nov 20 @ 9:24 am
Not sure where you want it saved..
Already does as cue points. Through the mix there will be cue points with the name of the tracks
And you can also turn on the setting recordWriteCueFile to save a cue file, that can be used with CD burners, uploading to sites that support (Mixcloud etc..).
The cue file contains the tracks
And lastly, its also saved to history file, that shows up as a playlist in the software
Or maybe you meant per track slit, using the record split feature.. Maybe that could be something, as a suffix to the record name set
geposted Sat 28 Nov 20 @ 9:40 am
