Can we have a confirm delete before we actually delete our filter and virtual folders?
geposted Thu 12 Nov 20 @ 6:46 pm
+1 for that
and by the way...
an undo/cancel when editing ^^
At least a deleted file can restore from trash...
But a cat on the keyboard definitively destroys the filter
unless using some the hard hacks :
1) button "crash" before it is written
2) the difficult steps :
- edit again same filter
- close broken filter
- copy paste from first edited to newly open one
- close first
- close last
Doing this Blindly and with extreme care, because edit boxes do not name the edited filter ...
if more than one is open to compare alternatives .... pray for the skin to not auto reorder the windows (crash, layout change, display change...)
Maybe would be fine to title the edit box too to know which one edit which script ^^
and by the way...
- close first
- close last
geposted Thu 12 Nov 20 @ 9:36 pm
Might come.
For now, these are just regular files on your drive.
So you can restore them from trash bin easily if you for some reason would want to undo a delete.
geposted Thu 12 Nov 20 @ 9:57 pm
ok...thanks
geposted Fri 13 Nov 20 @ 1:35 am
There is a confirmation depending on your operating system settings.
In Windows, right-click the Recycle Bin, select Properties, and then check 'display delete confirmation dialog'
geposted Fri 13 Nov 20 @ 4:25 am
