Hello ,
I am using the pioneer skin Ddj-Sb, that’s the same of my panel.
If I start to play music , the left jog wheel one the skin doesn’t turn around wen it’s playing.
The right side , no problem
I have installed it again , but it is still the same
Is this possible that there is a fault in the skin ?
I use the default skin from pioneer
geposted Tue 17 Nov 20 @ 8:01 am
Yes the skin is buggy and was never officially fixed
the fix is small, if you feel enough courage to try it: less 18 lines to fix in 9 easy steps
basically line 1037:
set to <panel name="joff" visibility="var '@$noroo' 0">
and line 1073 is the opposite:
set to <panel name="jonn" visibility="var '@$noroo' 1">
lines 1043 1053 1079 1090 2160 2170 2180:
<visual>
becomes
<visual type="rotation" source="get rotation">
and lines 1063 1102
<visual type="rotation" source="get rotation" visibility="deck 1 touchwheel_touch" >
line 2218:
<visual type="rotation" source="get rotation" visibility="deck 2 touchwheel_touch" >
line 1046 off: ==> on
<on x="1408" y="1373"/>
line 1107:
copy
<on x="1833" y="1725"/>
<off x="1833" y="1725"/>
line 823 add:
<panel x="+0" y="+0">
and line 1938 add:
</panel>
tweak: lines 953 2071 replace 54 with 30
<visual>
becomes
and lines 1063 1102
line 2218:
line 1107:
copy
line 823 add:
and line 1938 add:
</panel>
geposted Tue 17 Nov 20 @ 10:04 am
APPLY TO to "DDJ-SB Rework 2" Last updated: Fri 07 Dec 18
https://www.virtualdj.com/plugins/index.html?addonid=80384
(which have the issue you explain)
not "Pioneer DDJ-SB NowskiN Original Creation": By DjKaos2012 Last updated: Sat 08 Apr 17
or "Pioneer DDJ-SB 8Skin" Last updated: Mon 23 Feb 15
https://www.virtualdj.com/plugins/index.html?addonid=80204
geposted Tue 17 Nov 20 @ 10:20 am
