Are offered under the pitch slider to temporary slowdown/speed up the track (Pitch Bend) while pressed. On release the pitch will reset to it’s previous value.
My question: Is there a way to make the pitch bend value permanent? I know that traktor offers that option.
Sometimes I need to match speed perfectly without using the sync button and slider.
geposted Sat 21 Nov 20 @ 7:42 pm
that case it's not bend, it's just moving pitch with a button
repeat 30ms & pitch +0.001
repeat 30ms & pitch -0.001
geposted Sat 21 Nov 20 @ 7:49 pm
loco edit, you quoted my post before I fixed my typo
Yes, precisely, moving the pitch up and down with +/-
Where do I add those values?
geposted Sat 21 Nov 20 @ 8:10 pm
To the empty custom buttons in skin.
Or to keyboard mapper, or even on a controller button
(drop the repeat part of keyboard, since keyboard keys already repeat)
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/custombuttons.html
https://virtualdj.com/wiki/How-do-I-map-a-keyboard-shortcut.html
geposted Sat 21 Nov 20 @ 8:19 pm
Thank you, I have to go and study now.
geposted Sat 21 Nov 20 @ 8:22 pm
Its quite straight forwards...
But just ask if you cant get it right ;-)
geposted Sat 21 Nov 20 @ 8:24 pm
Just bear in mind that if you're moving the pitch (or bending it) in order to sync to another track, then you don't want to leave the pitch at that position because you've pushed it past the point where the BPM will be the same as the other track.
In other words, you've "accelerated" to "catch up", so you need to slow back down again, to remain level.
geposted Sun 22 Nov 20 @ 1:21 pm
