HEllo,
I can't update my VirtualDj by the Program
I can't install neither by the Latest downloaded version
here is the error :
"error writing to file : C:/program/virtualDJ .exe
Verify that you have access to this directory".
All updates before were OK all time. any idea?
link to img error: https://ibb.co/KbSLPhv
here is the error :
geposted Wed 25 Nov 20 @ 8:36 pm
          Try right-click the installer file, and choose "run as admin"...
And also try restart the computer, in case there is a frozen process or something using virtualdj.exe so you can not write to the file.
Although the error might have other potential causes, such as anti-virus software being too aggressive etc.
geposted Thu 26 Nov 20 @ 11:29 am
          I have the same problem, and there is no run as administrator option on right click....and yes i'm on the administrator account on windows 10.
    geposted Fri 27 Nov 20 @ 6:13 pm
          Yes,  There is no Admin.
I have reboot of course but same error.
i don t know if We should uninstall VDJ, then install the 2021.
i run windows 10. (and the installing files works on another computer running on Win10)
geposted Sat 28 Nov 20 @ 10:10 am
          In Windows security, maybe you activated the malware protection. Sometimes it can wrongly block files writing.
    geposted Sat 28 Nov 20 @ 1:51 pm
          I am receiving the same error on a new install on a new Windows 10 Home PC. I am the only account on the computer and it does not have run as admin it states grant admin full control which did nothing I have shut off Anti-virus and checked windows security for malicious software settings and still the same.
    geposted Fri 19 Feb 21 @ 10:06 pm
          I have same issue with Windows 11 pro.
    geposted Sat 19 Feb 22 @ 1:24 pm
Other machine with Windows 10 Home work fine.
geposted Sat 19 Feb 22 @ 1:25 pm
          My Windows is not on S-mode.
    geposted Sat 19 Feb 22 @ 3:19 pm
          I don't know what really happened, but when I turned on Onedrive, then VirtualDJ installed.
    geposted Sun 20 Feb 22 @ 8:42 am
          I solved the issue! For context, I recently got a new computer and connected my account to it. Meaning that OneDrive had the old vdj instillation in the cloud. So I couldn't open the program but still had the files on it. I simply had to delete the virtual DJ folder (which I couldn't find using the search tool) and then I could redownload the installer properly. Hope this helps!
    geposted Fri 04 Nov 22 @ 11:39 pm
