good going :), you can post it for review here
http://www.virtualdj.com/plugins/upload.html
geposted Sat 05 Dec 20 @ 1:23 pm
Thanks! I submitted it for review.
geposted Sat 05 Dec 20 @ 7:56 pm
Please name your files as following..
Definition: Faderfox DJ4.xml
Image: Faderfox DJ4.png
Mapping : Faderfox DJ4 mapping.xml
Zip just these 3 files together (no folders or nested sub-folders) and update your submitted Addon by re-uploading the zip file.
Thanks
Thanks
geposted Sat 05 Dec 20 @ 11:04 pm
I updated the files as requested.
I've also made a short manual how the mapping works and how to setup the controller, but the document is now not included in the package.
Many thanks!
Many thanks!
geposted Sun 06 Dec 20 @ 7:55 am
What does it take to get controller officially supported? If I check the supported hardware than the faderfox dj4 isn't listed at all. It would be nice to see it listed and that the hardware is detected out of the box without the need to download a custom mapper / definition.
Many thanks!
Many thanks!
geposted Mon 21 Dec 20 @ 3:56 pm
Hi. Is the Faderfox DJ4 config file available anywhere to download please? Is this working OK now?
geposted Fri 29 Jan 21 @ 12:26 am
geposted Fri 29 Jan 21 @ 10:54 am
