Hola, recientemente he adquirido un mixer Gemini PMX 10 , he bajado la version de virtual DJ LE con la licencia que viene con el equipo. cuando intento utilizarlo con DVS dice que no esta incluido en la licencia. la cual segun gemini deberia incliur.
a que se debera este error?, la licencia LE para este equipo inlcuye DVS?
gracias
gracias
geposted Tue 01 Dec 20 @ 2:11 pm
Please write in English or use the Spanish forum
Yes, the Gemini PMX10 LE includes DVS support, but has to be validated via our server. Try to register your LE serial at https://virtualdj.com/users/licenses.html and make sure your computer is connected to the internet when you open VirtualDJ LE with your PMX-10.
geposted Tue 01 Dec 20 @ 2:23 pm
yes , i sorry, you right
i download vitual dj le with code of my pmx 10, install, login and add the code, but when put virtual in dvs mode the software see not have dvs activate in this software/hardware
in license see limited (PMX 10), limited (timecode) but dont work, keep ask purchase
geposted Tue 01 Dec 20 @ 6:20 pm
I'm having the same issue with my PMX-20. I can't activate DVS on Audio > Inputs > Timecode Signal.
The LE license is activated.
geposted Thu 03 Dec 20 @ 1:36 pm
final explanation of virtual dj mail me:
Your controller did not come with a DVS license, and no such license exists.
Licenses Comparison (and Price)
What your controller came with is an LE license, (VirtualDJ LE 8 -GMPMX10) and to use Timescodes/vinyl/DVS you need a Pro Infinity license or a Pro sub.
PMX-10 or PMX-20
PMX-10 or PMX-20
geposted Fri 04 Dec 20 @ 3:01 pm
