I just now started working with the video option with VDJ, using a projector works great
as I was going through the settings I clicked on something and it started to show whats I was playing-(tracks I was playing)-kinda liked the option to do that, and thought about, I wanted keep using that option, but I must have unchecked it. But now I do not remember what area of the settings I was at to enable the each track withing the video I was using, very cool option, But I have looked again in the settings under video,etc just can not seem to find it. If anyone please point me in the right direction. I would most grafeful , feel stupid now I should have taken a picture of the setting area for this option, but please someone help me out on my stupity . Thank you very much
geposted Thu 03 Dec 20 @ 11:36 pm
sounds like you enabled/disabled/reset the video skin
rightclick on video preview and select "use videoskin"
its setting -> video : useVideoSkin
and setting -> video : VideoSkin
maybe you reset this one
can, be selected from settings -> interface
bottom left list is "Video Skins"
https://virtualdj.com/manuals/virtualdj/settings/interface.html
geposted Thu 03 Dec 20 @ 11:52 pm
ok will try that, thanks, will let you know
geposted Fri 04 Dec 20 @ 12:04 am
it works thank very much, brother
Thank you Thank you
Have a great weekend
Thank you so much for your help Nicotux
Thank you Thank you
geposted Fri 04 Dec 20 @ 12:07 am
Thank you so much it works, really appreiate it, have a great weekend
geposted Fri 04 Dec 20 @ 12:33 am
