In searching for the cause of VDJ crashes on my system I came across another unrelated cause of crashes. A percentage of webm videos cause VDJ 2021 to crash when the video window is opened. They play fine when the video window is closed but crash immediately when the video window is opened. These same files work perfectly on the VDJ 2020 version.
This is on a Windows 64 system build b6173.
I have 99 webm videos. This occurs on 11 of the 99.
geposted Fri 04 Dec 20 @ 10:32 am
Can you upload one that crashes your system for the developers to take a look ?
geposted Fri 04 Dec 20 @ 10:38 am
Sure. How?
geposted Fri 04 Dec 20 @ 10:46 am
Use any file transfer service suits you... Dropbox, Google Drive, WeTransfer e.t.c.
Then send the link to me via PM
geposted Fri 04 Dec 20 @ 10:53 am
Can home users PM? I don't see a button.
geposted Fri 04 Dec 20 @ 11:33 am
Post the link here and 'Ill remove it once I get the file
geposted Fri 04 Dec 20 @ 11:40 am
Setting safeVideoDecode to "no" fixed this.
geposted Tue 29 Dec 20 @ 2:57 pm
Cannot reproduce any crash here, the file plays fine in all cases.
What is your computer's video card ? Have you checked for drivers updates ?
geposted Tue 29 Dec 20 @ 9:25 pm
Video is Radeon RX 480. 8 gigs ram.
Yes I have the latest driver. It has updated once since the problem occurred.
If I play the video with safeVideoDecode "no" and change it to yes it immediately crashes.
Evidently whatever this function does my system doesn't like it.
geposted Tue 29 Dec 20 @ 10:14 pm
