What is the option "analyzesongsonview"? Enabled or disabled, it still analyzes all new songs added to virtual folders regardless off setting.
geposted Fri 04 Dec 20 @ 3:09 pm
It does what it says, what you are seeing is a need of virtualFolders
if you look at them in the operating system you'll see it holds length & bpm data [it uses this to auto relocate if you move the file]
So to go into a virtual folder a track needs to be scanned,if it's not scanned when you add it, it needs to be scanned there and then.
<song path="M:\Music\D & B\Fed\Fed. - bla bla bla(Back to dancecore).mp3" size="10720616" songlength="267.9" bpm="224.000" artist="Fed." title="bla bla bla" remix="Back to dancecore" />
geposted Fri 04 Dec 20 @ 3:51 pm
