salve scusate il disturbo ma non riesco a uscire da questa skin😔😔😬😬 x le impostazioni di vdj grazie a chi mi aiutera' buon proseguo
geposted Sat 05 Dec 20 @ 8:22 pm
English forum ... english please ^^ or Italian forum
uscire da una skin ? Exit from a skin ?
No way, you can only select a skin, not enter or exit it
settings -> Interface
or
Impostazioni -> Interfaccia
Badly access to settings depends on skin itself and sometimes it's not so easy to find
at worth ... exit VDJ and delete/rename the current skin you can't find settings in
VDJ will use default one
if you are talking about "new" default skin.... old one still available in settings
or
geposted Sat 05 Dec 20 @ 9:03 pm
