Please, can anyone help me? I have a Mixer One Dj-Tech ... and Virtual DJ even recognizes it, but I'm not able to configure it .... can someone help me step by step since the beginning of the configuration? .... Thank you so much ...
geposted Sun 06 Dec 20 @ 10:06 pm
Not sure what model you mean
https://virtualdj.com/products/hardware.html?brand=djtech
But generally speaking it should be plug and play (might require drivers installed first)
What is not working?
geposted Mon 07 Dec 20 @ 6:22 am
this one?
https://www.bhphotovideo.com/c/product/677043-REG/DJ_Tech_MIXER_ONE_Mixer_One_Professional.html
can't find any real info for it
geposted Mon 07 Dec 20 @ 8:01 am
If locodog was right for the model
https://www.manualslib.com/manual/1393231/Dj-Tech-Mixer-One.html
if this is this one
https://www.adorama.com/djkontrolone.html
may already be supported
http://54.80.172.10/products/hardware.html?model=djtkontrol1
if this is this one
geposted Mon 07 Dec 20 @ 9:42 am
Audio configuration should be done automatic by the software but to check it go into settings and click onto audio then you should see master chan 1&2 and headphones should be chan 3&4 it should work and read the instructions that came with it that should help
geposted Mon 07 Dec 20 @ 6:06 pm
No, because the Mixer One isn't natively supported.
No, because the Mixer One doesn't have any audio I/O.
geposted Mon 07 Dec 20 @ 11:33 pm
