Probably just overlooking something but is there a way to have the equalizer reset after each track? I am talking about the eq buttons on front panel, there is the Gain then the high, mid, and low eq knobs, when I remove a track the Gain resets to center, but the 3 others remain, I have to manually set them back as each track may need different settings. This is totally not a big deal but would be nice to have a reset button or like the gain reset to center when track is removed..
Thanks,
Danny
Thanks,
Danny
geposted Wed 09 Dec 20 @ 4:22 pm
search options for resetEQ
geposted Wed 09 Dec 20 @ 4:26 pm
Thanks for the response, that is not exactly what I want to do, I am not wanting to reset on start up, what I am looking to do is as VDJ is running and I am adding and removing tracks from each deck, I would like the eq to reset to center when I remove the track for the next track in that deck like the Gain does, the Gain resets to center each time the track is changed, not he program loading.
If that makes sense lol
geposted Wed 09 Dec 20 @ 5:07 pm
Never mind my last response, that is exactly what I wanted lol!!!
Thank you so much you just saved me a lot of eye sight lol!!!
geposted Wed 09 Dec 20 @ 5:10 pm
