Topic: Track skipping
Load a track A... track skips, load another track (B), track B OK, reload initial track A again end it becomes OK. It happenend twice.... and once during a live gig. Not ideal... VDJ became very heavy with STEMS. Waveforms are not as fluid neither. Please, we us VDJ as our msusical instruments... it has to work every time. Any updates soon? Or a lighter version like in old times?
geposted Sat 12 Dec 20 @ 5:28 pm
You can set mathengine to disabled to try if it's related to stems
geposted Sat 12 Dec 20 @ 6:54 pm
Tx will try... two occasions, since the STEMS update. Let's see if I get it again.
geposted Sat 12 Dec 20 @ 7:10 pm
Do you knwow of other settings that improve play performance or wavefor fluidity when deactivated?
geposted Sat 12 Dec 20 @ 7:27 pm
Setting experimentalSkinEngine to yes can help a bit.
If you do want to use stems the mathenginePriority option and useLowPowerGPU options can also help
geposted Sun 13 Dec 20 @ 4:59 am
Tk a bunch... will try all that, let's hope new updates wont make VDJ any heavier.
geposted Sun 13 Dec 20 @ 5:27 pm
Pedrolartiste wrote :
Tx a bunch... will try all that, let's hope new updates wont make VDJ any heavier.
geposted Mon 14 Dec 20 @ 11:33 am
Load a track A... track skips, load another track (B), track B OK, reload initial track A again and it becomes OK. It happenend twice.... and once during a live gig. Not ideal... VDJ became very heavy with STEMS. Waveforms are not as fluid neither. Please, we use VDJ as our msusical instruments... it has to work every time. Any updates soon? Or a lighter version like in old times?
geposted Mon 14 Dec 20 @ 11:34 am
