Topic: havingHaving trouble with settings
Evol35LE userMember since 2014
so i go into options and get everything where i want it and then i exit out. it seems like i never did anything to the settings and i go back in and are still the same when i changed them.
What's going i haven't a clue.
geposted Tue 15 Dec 20 @ 6:51 pm
settings are saved to /documents/virtualdj/ to a file called settings.xml
any chance its write protected, for example if copied over from other pc.
Or better yet, just rename settings.xml and let VirtualDJ create a new one with proper permissions
geposted Tue 15 Dec 20 @ 7:24 pm
