Topic: Timecode Input Stopped working
Hi Guys
I have an odd issue. My timecode input seems to have stopped working:. I'm using: Denon DS1 & Serato Timecode. It worked perfectly and suddenly stopped. I'm using a windows machine, i7 8th gen, 16gb RAM and NVME SSD. The outputs from the soundcard work fine i.e I can hear music but just no Timecode and vinyl control. I've triple checked my config in Virtual DJ and have also checked the hardware with Serato, works fine.
Any ideas? Please help :( I've just switched from Serato and after experiencing the amazing feature set in VDJ, I don't wanna go back.
geposted Fri 18 Dec 20 @ 6:06 pm
a picture of your audio config usually helps
geposted Fri 18 Dec 20 @ 6:16 pm
Thanks, I actually solved it. I was overlooking the config. Used ASIO in the Denon Soundcard and that did the trick!
geposted Fri 18 Dec 20 @ 6:18 pm
**solved**
DJSabz-SA wrote :
Hi Guys
