Topic: 4 deck usage on 2 deck controllers? [DDJ-400]
Virtual DJ is absolutely amazing, and I am kinda broke. Is it possible to use the new 2021 skin but have the 2 decks act as four?
I searched here and did a bit of googling but only found older posts.
geposted Sat 19 Dec 20 @ 1:07 am
I cant see why they cant toggle between decks using a keyboard stroke or dicer or what ever button you want to scrap.
Any resources to point me in the right direction?
deck left invert_deck
deck right invert_deck
A variant from @locodog, I set up the "shift + cue" to swap just the deck on the side I pressed (so pressing "shift + cue left" will swap left decks and "shift + cue right" will swap right decks") using the slightly modified script:
device_side 'left' ? deck left invert_deck: deck right invert_deck
thanks mate!!!!
works fine for me!!!!!
