I would like to ask if there is a way to get a execute script for the Event Sceduler to start (ex. play sample) when we mix to a new song?
Dont want it to use the clock to start, I want it to use fader/crossfader with a setting for delay to start.
Or if this could be developed in the future.
Missing this feature in the settings.
geposted Tue 22 Dec 20 @ 10:29 am
"Dont want it to use the clock to start, I want it to use fader/crossfader with a setting for delay to start."
Well you don't want a time scheduler ^^
just a script started with a crossfader/fader value
i.e. a rsi waiting for a specific variable as delay to start
geposted Tue 22 Dec 20 @ 11:38 am
Sounds like that could be made or imported in the "Event Sceduler" ?
geposted Tue 22 Dec 20 @ 4:04 pm
Everything depends on what you have in mind
activate an action when a slider/crossfader reach a position is possible
geposted Tue 22 Dec 20 @ 5:25 pm
Dev Team ?
geposted Wed 23 Dec 20 @ 8:06 am
Its no "at crossfade" currently, but can easily be done with script in the Event Scheduler.
Maybe "at crossfade" could be added as a setting, could perhaps make sense. But for now just run the Event Scheduler as a "loop" (restarting itself) and have an entry check if crossfader position has changed, if so run sample (or something).
Or do same in a script with repeat_start to to same, check if crossfader has moved etc
geposted Thu 24 Dec 20 @ 12:42 pm
