It would be extremely helpful if we could right click playlists & folders in the library and have a virtual folder option from that.
Thanks!
Thanks!
geposted Wed 23 Dec 20 @ 10:48 pm
you mean add to?
Or show location or?
Not sure what you meant by "open from that"
geposted Thu 24 Dec 20 @ 9:53 am
What I'm asking for is the ability to right-click a playlist or folder from my library and be able to create a virtual folder from that. Instead of create the virtual folder, then go to playlist or folder and copy tracks from that. A simple right-click command would be awesome.
geposted Tue 29 Dec 20 @ 11:02 pm
So nothing virtual about it? Just a link to a folder?
Because I believe that is what Favorite folders are for
You get a favorite folder by right-clicking and selecting "Set as favorite"
You can then mix and match your virtual folder and favorite folders (and filter folders) as you like
geposted Wed 30 Dec 20 @ 12:34 am
No, that’s not what I’m asking for. I’m mainly asking for a shortcut to create a VIRTUAL folder from a playlist.
geposted Fri 01 Jan 21 @ 8:13 pm
