I'm writing a script for LEDs on my DDJ-XP1 to display a Graphic EQ, and need to be able to ask VDJ for the levels on a particular frequency or band of frequencies on the master output. Does this exist? If not how hard would it be for devs to implement in an upcoming release? To keep it simple 8 bands would suffice 0-80hz, 81-200hz, 201-800hz, 801-2khz, 2k-5khz, 5k-10khz, 10khz-15khz, and 15k-20khz, or tied into the built-in 3band eq and using those 3 bands set by the user prefs.
geposted Tue 29 Dec 20 @ 6:51 pm
You can tweak your own range for the 3-band EQ
Little more tricky to show what frequency its at during use, the action (for example eq_low_freq) returns a value to the knob position (0 to 1)
Can also see this older post, might be of interest https://www.virtualdj.com/forums/226926/General_Discussion/VDJ_Equalizer_Settings.html
geposted Tue 29 Dec 20 @ 7:28 pm
There is also a 10 band EQ plugin, that you might prefer to map
Will be quite easy
Will be quite easy
geposted Tue 29 Dec 20 @ 7:32 pm
Thanks Rune, I'm familiar with the eq settings; I'm looking for a VDJ Script query to return the levels of a particular band in real time. I'm trying to build a multi-band VU meter(or graphic eq display) script for a controller.
Below is what I've done so far, but it's just the L/R VU meter repeated with slight variations to make it appear like a GEQ. I had to filter the audio because YouTube are DR nazis.
geposted Sun 03 Jan 21 @ 10:43 pm
Currently only available as a whole for skins with "equalizer" skin element, but would indeed not be too hard to make individual spectral bands available through vdj script as well.
geposted Mon 04 Jan 21 @ 6:21 am
I think it would be a nice addition.
geposted Thu 14 Jan 21 @ 7:19 pm
It used to be possible in old versions of VDJ.
Certainly skinners such as DJ Format used a method to create multi-band analyser displays in their skins.
When I modified Mixlab for VDJ 8 I couldn't use that part of the code any more.
geposted Sat 16 Jan 21 @ 10:40 am
There is a skin element that allows you to build spectrum analyzer.
But you can't use that element to output values on controller leds/bars.
For skins, it's absolutely possible to add spectrum analyzer. And I think some skins (including one of my own) use it already ;)
geposted Sat 16 Jan 21 @ 3:22 pm
What about add new verbs?
get_vu_meter_1
get_vu_meter_2
get_vu_meter_3
get_vu_meter_4
get_vu_meter_5
get_vu_meter_6
get_vu_meter_7
get_vu_meter_8
get_vu_meter_1
get_vu_meter_2
get_vu_meter_3
get_vu_meter_4
get_vu_meter_5
get_vu_meter_6
get_vu_meter_7
get_vu_meter_8
geposted Wed 09 Jun 21 @ 10:20 am
what about to use existing verb "get_spectrum_band" ?
there are 32
get_spectrum_band 1
get_spectrum_band 32
there are 32
get_spectrum_band 1
geposted Wed 09 Jun 21 @ 10:38 am
And if you need less, "get_spectrum_band 1 8", "get_spectrum_band 2 8", etc... should now also work
geposted Wed 09 Jun 21 @ 11:00 am
Nice, thank you! But in VERBS there is no mention about it.
[dealt with]
[dealt with]
geposted Fri 02 Jul 21 @ 9:31 am
I know, there is wrong thread, but we need also action for set POI CUE ACTION via pads. Something like that
cue_action 'Fog' 'green' 'marker_only' 'os2l_button "Scene 1"'
cue_action 'Strobo' 'green' 'marker_only' 'os2l_button "Scene 2"'
etc
Without this is very anonnying set each track, editing in POI editor.
etc
geposted Fri 02 Jul 21 @ 9:39 am
