Topic: Loop length
zanardPRO InfinityMember since 2003
Loop length doesn't work.
Is it to you?
Thanks.
Fabio.
Example:
<slider action="deck left loop_length" relative="yes" orientation="round">
<size width="517" height="517"/>
<pos x="35" y="393"/>
<down x="35" y="393"/>
<clipmask x="607" y="3145+161"/>
<mousemask x="607" y="3145+161"/>
<fader move="circ" sensibility="3000">
<mask x="607" y="3145+161"/>
</fader>
</slider>
geposted Thu 31 Dec 20 @ 7:16 pm
NicotuxHome userMember since 2014
I think it's better 'loop_select'
which can modify loop duration from a slider
geposted Thu 31 Dec 20 @ 8:20 pm
Thanks guys but it doesn't work.
I really think it's a bug.
Checking the commands the loop_length still exists.
It worked in the 2020 version.
geposted Tue 05 Jan 21 @ 9:53 am
loop_length works on slider here... .
Whats not working? or how do you want it to work?
geposted Tue 05 Jan 21 @ 10:06 am
Loop_move and adjust_cbg they work well, but don't loop_length.
Watch the video:
Or there is something wrong with the code, but I don't think because it has always worked before...
Thanks
geposted Tue 05 Jan 21 @ 5:31 pm
