Topic: WeGo1 right deck not working
geposted Fri 01 Jan 21 @ 1:12 pm
geposted Fri 01 Jan 21 @ 2:32 pm
dj casper yruk wrote :
i cannot sign in on the software says cannot connect to servers its doing my head in please help
You have previously had a cracked version of VDJ installed
Part of the crack is to change the network setup on the laptop so that the software can't connect to the servers, and that now affects the real version of the software
If you search for it on this forum there are links to some tools than can cleanup your network settings
After that you should be able to connect to the servers again
geposted Fri 01 Jan 21 @ 2:35 pm
