Topic: Virtual Folder missing files remain
lincol2PRO InfinityMember since 2011
Unable to clear files from the Virtual Folder after files are deleted. The deleted files appears with with a Red X mark in the Virtual Folder and "Remove missing files from search DB" does clean it.
Any suggestion on how to clear it?
geposted Wed 13 Jan 21 @ 6:13 pm
A virtual folder is similar to a playlist.
Select the files you no longer want and press the delete key on your keyboard, or right-click and select 'remove from virtual folder'
geposted Wed 13 Jan 21 @ 6:15 pm
Yes, thank you
geposted Wed 13 Jan 21 @ 6:27 pm
