Topic: Reloop Touch screen does not display
I can use tha touch screen feature but eye have to view it on my laptop. Tha screen on tha mixer does not show anything on tha screen with tha exception on start up. If anyone has any advice as to what is happening or if I am missing something, please help
geposted Fri 22 Jan 21 @ 1:27 am
If it's working like it's supposed to, then the controller screen is running as an extended screen on your laptop
So if you see the screen content as a pop-up on your main screen, you simply drag and drop it to the Reloop Touch (probably to the right)
Also note that you need to download the skin for the controller screen, but you have probably already done that
geposted Fri 22 Jan 21 @ 9:03 am
Has it ever worked for you before updating your Mac to BigSure , or first time using Touch with this OS ?
geposted Fri 22 Jan 21 @ 11:28 am
