When I updated Virtual DJ, put in any audio file into the A or B slot, the audio wave are not showing up. I've tried uninstall and redownload and I still have this problem. Can anyone help me fix this problem?
geposted Fri 22 Jan 21 @ 9:37 pm
I have the same issue. Once I upgraded to 2021 my waveforms are gone. They come back when I switch to a color display of waveforms vs. shapes.
I have v8.5-64 b6263. I have an NVIDIA 980 GTX SLI with driver version 436.48. I can't upgrade the driver since it bricks my displays. I have to do a System Restore after trying to upgrade.
geposted Sat 23 Jan 21 @ 12:55 am
Can you show me how to do what you did?
geposted Sat 30 Jan 21 @ 11:36 pm
Run this installer to update with a fix for that issue
https://www.virtualdj.com/download/pc/6281 (Windows)
https://www.virtualdj.com/download/mac/6281 (macOS)
geposted Sat 30 Jan 21 @ 11:53 pm
I am also having the same issue. I have a windows 8.1 laptop. Will this installer remove all of the color coded files I have. about a year ago I got another update that removed my colored explicit, Country and Karaoke files. I had to re-color over 30 thousand files.
geposted Mon 01 Feb 21 @ 5:40 am
Installing an update doesn't affect the contents of the database (where that info is stored). Even if it did, or there was a risk of it, that's why you should keep a backup of the database.
geposted Mon 01 Feb 21 @ 2:12 pm
