Bonsoir, comment fait on pour enregistrer notre micro via l'enregistrement de virtual dj 2021 ? Car le micro marche bien au niveau des haut-parleurs mais n'est pas enregistré en même temps que le mix
geposted Sun 24 Jan 21 @ 10:39 pm
On some controllers mic is routed directly to speakers and never heard by the computer (or VirtualDJ).
For example see here for Numark NV https://www.virtualdj.com/manuals/hardware/numark/nv/inputs.html
To record mic,. connect an audio cable from the master/boot/rec out of your controller to a free line-in at computer.
Then add a record entry in VirtualDJ sound settings to this particular line-in (record loopback)
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
geposted Sun 24 Jan 21 @ 11:13 pm
