Hello.
I started using VirtualDJ not that long ago for fun and it was working fine, until the last 2-3 updates got released. The strange thing is that if I uninstall and re-install the program, it works normally right after the installation, and when I close the program and open it again, all the Stems buttons are not doing anything (Vocal/Instru/Bass/Kick/HitHat), until I uninstall and re-install again.
I read some topics and I saw someone suggesting that the hardware is not strong enough to work as intended, however I'm using Core i9-10980XE with 64GB RAM and 3090, so I doubt that's not enough.
What is it that can make the software do this? Is it fixable or is it a bug and the workaround is to re-install it every time I want to use it?
geposted Mon 25 Jan 21 @ 11:16 am
For the nVidia 3000 series you can try to use the current Early Access release 6276:
https://www.virtualdj.com/download/build.html
geposted Mon 25 Jan 21 @ 11:24 am
@Adion .. I think this fixes the problem, thank you very much.
geposted Mon 25 Jan 21 @ 1:47 pm
