I installed the latest update. The stems are not working as before. Example. I mute the vocal option and now and the entire track is muted. No instruments or any other control. The track is still playong
geposted Mon 25 Jan 21 @ 11:05 pm
It's all working correctly here. Please provide more information.
Mac/PC? OS? Graphics? Selected options (GPU/CPU)?
geposted Mon 25 Jan 21 @ 11:37 pm
Win 10 pc
geposted Mon 25 Jan 21 @ 11:53 pm
GPU is selected
geposted Mon 25 Jan 21 @ 11:54 pm
When I select vocal from the stems, the entire track is muted
geposted Tue 26 Jan 21 @ 12:54 am
Is this the case with all Tracks ?
Same results if you choose mathEngine setting to CPU ?
Any chance you modified the Stems Pads page ? Can you check Documents//VirtualDJ/Pads folder and delete stems.xml if there ?
geposted Tue 26 Jan 21 @ 11:57 am
stems.xml is not there
geposted Thu 04 Feb 21 @ 7:34 am
