I have just purchased a virtual DJ pro license and I’m trying to connect my Gemini 7000 cdmp to virtual DJ but I can only find old instructions on how to do this, can anyone help me please?
geposted Mon 25 Jan 21 @ 11:35 pm
Should probably be a lot similar to old instructions.
But even easier in newer VirtualDJ. Should get a popup that the controller is detected.
And if needed a link to download drivers. What happens when you connect?
Just in case you didnt see this guide (but SKIP the part where it says download MIDI/HID files, not needed now)
https://geminisound.com/blogs/help/cdmp-7000-pc-virtual-dj-setup-guide
Or https://support.geminisound.com/hc/en-us/articles/205664438--CDMP-7000-PC-Virtual-DJ-Setup-Guide
geposted Tue 26 Jan 21 @ 11:12 am
