HI...Not sure if I have a setting wrong but my samples show playing when clicked but no sound....if you click and hold it plays as normal...probably me.....
PS I have just updated.....
Trev
Trev
geposted Sun 31 Jan 21 @ 11:30 pm
There's a setting and a button on sampler area that adjusts just that!
https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
Check item Nr 2 (Trigger Mode)
You have changed it to hold
Most likely you want it back to (default) on/off
geposted Sun 31 Jan 21 @ 11:34 pm
Also in the link posted by Phantom check that the "audio output" is as you want it.
Most likely would want it set to master as shown below:
geposted Mon 01 Feb 21 @ 7:04 am
Spot on guys thanks so much.......I really should do a bit of study.....Trev
geposted Mon 01 Feb 21 @ 8:36 am
