When using the Metal option a lot of video fxs are lost including my main fx which is Syhponserver8 because I use Mix Emergency to handle the video.
I hope this is all being looked at or atleast the plugin creators are being informed that yet again their plugins will be broken and not work with VDJ....
Also had a series of crashes about an hour or 2 ago, any insight as to what caused them??
I’m sure it’s the Metal option but I wanna be for sure before I shut it off until it’s improved.
geposted Mon 01 Feb 21 @ 4:49 am
Your crash appears to be from a video plugin called videobars.
geposted Mon 01 Feb 21 @ 4:59 am
Yup that was one of them.
Thanks
I’ll quit using the Metal option until it’s improved or at the very least Syphon still works with it on.
Thanks
geposted Mon 01 Feb 21 @ 12:44 pm
