Anyone having issues with Off Air Message when sending folks to listen to your station? No one answers my question from VDJ
geposted Thu 04 Feb 21 @ 4:43 am
You had lots of answers in your previous post about just that.. .
You probably need to open port 8000 for incoming connections, see here:
https://www.virtualdj.com/wiki/open%20port%20for%20direct%20broadcast.html
The direct connect broadcast feature require people to be able to connect to your computer to listen, in other words you are the "server".
If you cant get it to work, the option would be to broadcast to a server instead.
And there are plenty of free ones etc to use. See here:
https://www.virtualdj.com/wiki/broadcast%20to%20a%20radio.html
These are very easy to make work and does not require opening of ports etc ;-)
geposted Thu 04 Feb 21 @ 1:29 pm
