Hi I am not sure if this is the right place to ask or if it is even possible. I am using the Impulse 500 with Virtual DJ 8 and I am wishing to turn off the beat align arrows. Only because some of the tracks I mix the beat grid is slightly off forcing me to manually sync them so I find the beat align arrows slightly off putting when flashing red. Perhaps I need to turn off the beat grid which I don`t think is possible as I have researched this before. Thanks for any advice and help.
geposted Fri 05 Feb 21 @ 12:24 pm
i think you would be better off manually correcting the beat grid on tracks that are off then not using it some FX rely on it to work correctly.
more info -> https://www.virtualdj.com/manuals/virtualdj/editors/bpmeditor/index.html
geposted Fri 05 Feb 21 @ 12:55 pm
Thanks I did consider it but decided it would take much longer than just using my headphones and syncing manually. Also want to stop relying on sync so much which is why I was looking to hide the beat grid. Perhaps their is a skin for that.
geposted Fri 05 Feb 21 @ 1:02 pm
