I have searched but not found anything recent in regards to Big Sur. Sorry if I missed it. I have yet to upgrade from Catalina to Big Sur. Does anyone know if there are any problems with VDJ working with the upgrade?
geposted Fri 05 Feb 21 @ 9:03 pm
Been working fine for quite some time. Just make sure your controller is compatible if you have one.
geposted Fri 05 Feb 21 @ 9:46 pm
Yeh, I've been using Big Sur with VirtualDJ since release. I also use Class Compliant Denon Controllers MC7000 & MC6000 MkII. I also use the Paragon plugin 'NTFS for Mac' which has just been made compatible (in the Early Access release b6294) so that I can use external NTFS formatted drives too.
System Specs;
MacBook Pro 15” 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Big Sur 11.1, 500gb SSD Bootcamped with Windows 10 x64bit. External WD Passport Ultra 2Tb HD containing Music & Video databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2021 b6294 and Controllers - Denon MC7000, Denon MC6000 MkII.
System Specs;
geposted Fri 05 Feb 21 @ 10:32 pm
Does it work with the new update to BigSur the 11.6.2 version?
geposted Thu 06 Jan 22 @ 4:49 am
yes
geposted Thu 06 Jan 22 @ 4:56 am
J’ai du mal avec mes vidéos depuis la mise à jour de Macos Big Sur 11.6.5.
Mes vidéos bloquent et j’aime pas
geposted Wed 23 Mar 22 @ 2:46 pm
