I just started using this button on left down corner, zoom browser, and when I click it back to normal view, the skin is pretty buggy and not showing correct view, like the skin doesn't refreshs like it should when closing the big browser mode. I have to select layout pro again to fix it.
Is this a new bug or something I have overseen a fix for earlier?
Win10, virtual dj 32bit 8.5 32 b6294 using pro 4ch mode
any tip?
any tip?
geposted Fri 05 Feb 21 @ 10:39 pm
Would be much better if you switch to 64-bit version by now.
Simply run the installer to install that version (database etc stays intact).
https://virtualdj.com/download/
That being said, no such issue with 32-bit version my end.
In settings, try set experimentalSkinEngine to "no"
As well as upgrade the graphic drivers on computer.. .
And ideally, change to 64-bit version of VirtualDJ as well ;-)
geposted Fri 05 Feb 21 @ 11:27 pm
Ah, thanks. ExperimentalSkinEngine, that was set to yes. Switched it to no and now it works fine.
I also use 64bit version sometimes but I cant let go of milkdrop as my wall-art with projector..." addicted? " :p
geposted Sat 06 Feb 21 @ 3:07 am
SBDJ has a 64 bit version of Milkdrop working nicely now - beta available on his web site.
geposted Sat 06 Feb 21 @ 10:52 am
couldnt find it... link?
geposted Sat 06 Feb 21 @ 5:06 pm
Like I said, it's on the SBDJ web site. The link is in his profile.
geposted Sat 06 Feb 21 @ 9:26 pm
It's not even beta yet, it's a working alpha, once it has dials & buttons in the fx gui then it's beta, very likely soon to be a release. but once it's a fully working item, then the suggestions for tweaks will start coming in [I haz listz]
geposted Sat 06 Feb 21 @ 10:29 pm
