There is a graphic problem only when using VDJ in full screen mode (1920x1080)
Even if you change the layout, the problem persist.
VirtualDJ Version 6294
Thank you
Thank you
geposted Mon 08 Feb 21 @ 8:38 pm
Try update your graphic card drivers (and Windows).
And in the Intel graphic card settings, try set to full 3D, max performance
and if that doesnt fix it, then in VDJ settings, try set experimentalSkinEngine to "No"
geposted Mon 08 Feb 21 @ 8:58 pm
Hi Rune,
Thank you for your message.
All drivers are up to date, even graphics drivers.
I tested to disable all experimental* options and the problem is the same.
I believe the problem has been present for 3-4 weeks. I regularly use the Eary Access builds and it seems to me that this problem did not exist in December.
Thank you
Thank you
geposted Tue 09 Feb 21 @ 9:33 am
