Hi,
I continue to test the latest beta versions, in this case BUILD 6294 (2021-02-07) and I run into this problem.
When I press the Loop button on my Denon SC5000M, the VDJ does not start the loop right at the beat where I hit the button at the time, but rather it moves back a few beats, even, it is almost impossible to guess that it fits right in the bar of the grid of the first beat of a series of 8, 16, 32, etc..
Does this happen to someone else?
Thanks.
Thanks.
geposted Tue 09 Feb 21 @ 7:05 am
Search in VDJ Settings->OPTIONS tab for loopbackmode and set it to No (if not)
geposted Tue 09 Feb 21 @ 9:59 am
Solved. Thank you @djdad.
The option was in "smart". I changed it to "no".
Greetings.
Greetings.
geposted Tue 09 Feb 21 @ 6:52 pm
