Hi all I’m thinking on upgrading my hardware and I don’t know witch nvidia cards are ok for stems isolation. I know minimum requirements paper says nvidia 9xx but I don’t know if gforce gtx series are ok or not (I know nothing about graphic cards)
Can anyone help me pls
geposted Wed 10 Feb 21 @ 8:26 pm
nvidia 9xx includes Nvidia GTX 9 series
https://en.wikipedia.org/wiki/GeForce_900_series
So that and above should all work well ;-)
10 series (or 10th gen), 16 series 20 series etc
The number after 9 or 10 etc, gives an indication of speed/power.
In other words 950 is slower than 980, but both should be ok.
If you get something with 70 or 80 at end, they will work very well for video, gaming, stems and more ;-)
Something with 50 or lower is more mid range, but still ok.
geposted Wed 10 Feb 21 @ 8:41 pm
More technically anything with Cuda 5.0 (compute capability) support or better
https://en.wikipedia.org/wiki/CUDA#GPUs_supported
(so even older 7xx will do stems on GPU, but not as ultra fast as say 10xx series)
geposted Wed 10 Feb 21 @ 8:44 pm
I would go for nvidia geforce 10xx, 16xx or RTX series.
geposted Wed 10 Feb 21 @ 9:29 pm
