Hello all!
I'm trying to set up VDJ perfectly as I am still used to mix with the old version Virtual DJ 7.
When I load tracks into VDJ7, the Auto Gain works perfect, it limits the tracks which are too loud and volumes up the tracks which are too soft.
Now, when i use the most recent version of VDJ, with the correct settings (AutoGain + Remember), it seems not to work as it should. Tracks are still in red zone on equalizer and a lot of difference inbetween tracks.
Does somebody know how to properly set up VDJ so I don't have to bother on Gain anymore?
(This is the only reason I still mix tracks on VDJ7. This allowes me to mix without headphones).
Both VDJ7 and Recent VDJ are set on Gain Auto + Remember, you would say they work exactly the same, but they don't.
Thanks in advance!
Thanks in advance!
geposted Sat 13 Feb 21 @ 9:09 am
Set zeroDB to -3 or -6
geposted Sat 13 Feb 21 @ 9:15 am
And set autoGain to auto.
(See https://www.virtualdj.com/wiki/VDJ8%20Limiter.html for more info)
geposted Sat 13 Feb 21 @ 9:18 am
Thanks! This also helps me with the clipping issue when mixing 2 tracks.
geposted Sat 13 Feb 21 @ 9:37 am
Done that and it seems to solve the issue.. I've also set this one to NO: gainSliderIncludesAutogain: yes
Now i actually can see how much a track is adjusted. But when I mix with my controller, I have to remember to set it to yes.
Thanks!
geposted Sat 13 Feb 21 @ 9:39 am
