Hi all, I am trying to get the mic to work between my Traktor S2 Mk2 and VDJ. The mapping looks correct, the volume lowers when the mic button is activated and the mic button is activated in the VDJ Master menu and it's volume up. In the Audio Settings I have the mic set to Traktor Kontrol S2 MK2 (WASAPI), chan 1&2. I have adjusted the Mic Volume on the back of the deck.
But no sound via the mic to speakers.
Suggestions appreciated.
geposted Sun 21 Feb 21 @ 2:49 am
Is your audio setup like this?
geposted Sun 21 Feb 21 @ 4:07 pm
These are the current settings...
geposted Mon 22 Feb 21 @ 1:50 am
Try to install the NI (ASIO) driver for S2 MKII and use that instead of the Windows WASAPI in VirtualDJ Audio setup.
Also check if your device is on the latest available firmware.
Visit https://www.native-instruments.com/en/support/downloads/drivers-other-files/ and scroll down to "TRAKTOR KONTROL S2 MK2" section
geposted Mon 22 Feb 21 @ 3:23 am
Sounds a perfect plan, thanks I will give it a go.
geposted Mon 22 Feb 21 @ 6:59 am
The ASIO driver along with the USB driver to the trick, thank you!
geposted Mon 22 Feb 21 @ 12:04 pm
geposted Tue 23 Feb 21 @ 6:39 am
