after latest update vdj starts, shuts down and restarts repeatedly, how to solve this
geposted Thu 25 Feb 21 @ 4:08 pm
Try rename settings.xml in /documents/virtualdj/ just to rule out a bad plugin, skin or setting
And start VirtualDJ after you have done that.
geposted Thu 25 Feb 21 @ 4:23 pm
done that still same result
geposted Thu 25 Feb 21 @ 10:50 pm
Strange.
Without uninstalling anything, try run the full installer from site, just incase something got corrupted
https://www.virtualdj.com/download/
And if still fails, you can try contact support here, and they can take a remote look:
https://www.virtualdj.com/help/
geposted Thu 25 Feb 21 @ 10:57 pm
why doesnt my crossfader go from 0 to 100 it only goes from 43 to 100 all this after update
geposted Thu 25 Feb 21 @ 11:08 pm
Where you see 43?
And guess you solved the program start then? At least its not an instant start, restart loop.. as I thought you meant.
geposted Thu 25 Feb 21 @ 11:12 pm
i am not amused with the latest update, reinstalled all my drivers, updated drivers, reinstalled vdj, renamed the settings.xml. i do have the program running now how ever my crossfader doesnt pick up from 0% but from about 50% and then up to 100% so mixing from one deck to the other doesnt work. never had that before, also my faders for the effects dont work properly.
geposted Thu 25 Feb 21 @ 11:31 pm
For the crossfader and faders, do you have a custom mapper perhaps?
Check in settings => mapper, and for the controller select "factory default" at top right corner.
geposted Thu 25 Feb 21 @ 11:50 pm
have already done that
geposted Thu 25 Feb 21 @ 11:57 pm
so much is really fucked up never had this after an update. i cant believe its my mixer cause it was working fine yesterday
btw i work with reloop touch on a laptop
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 2630QM @ 2.00GHz
Sandy Bridge 32nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
CLEVO CO. W25xHNx (SOCKET 0)
Graphics
Generic PnP Monitor (1366x768@60Hz)
RELOOP-TOUCH (1024x600@60Hz)
Unknown DisplayLink USB Device (Undefined)
Intel HD Graphics 3000 (CLEVO/KAPOK Computer)
2047MB NVIDIA GeForce GT 540M (CLEVO/KAPOK Computer) 58 °C
ForceWare version: 391.35
SLI Disabled
Storage
894GB TOSHIBA-TR150 (SATA (SSD))
931GB Western Digital WD Elements 1042 USB Device (USB (SATA) )
3726GB Seagate Backup+ Hub BK USB Device (USB (SATA) )
3726GB Seagate Expansion USB Device (USB (SATA) )
4657GB Seagate Expansion USB Device (USB (SATA) )
Operating System
CPU
RAM
Motherboard
Graphics
SLI Disabled
Storage
geposted Fri 26 Feb 21 @ 12:05 am
My guess is that its perhaps something else, not the VirtualDJ update itself..
But you can always roll back to earlier versions and test
Simply download from here:
https://www.virtualdj.com/download/build.html
6263 was the Public version before latest update (unless you have turned on Early acccess for beta)
geposted Fri 26 Feb 21 @ 12:11 am
