I recently uninstalled and reinstalled my Virtual dj software, I am now experiencing problems with it freezing and also now I do not access to stems...never had this problem before...HELP...
geposted Sun 28 Feb 21 @ 12:21 am
did you change settings? like mathengine..
Else stems should be there...
If you try stems on the performace pads (using the stems pads), you are not getting any results?
If so, check mathengine in settings, that its set to gpu (if nvidia card) or cpu..
geposted Sun 28 Feb 21 @ 12:08 pm
