Tengo una XDJ-XZ totalmente actualizada , al igual que el VIRTUAL DJ 2021.
Pero me funcionan los STEAMS solamente cuando uso los PADS
NO FUNCIONA CON LAS 5 PERILLAS del EQUALIZADOR.
¿QUE PUEDO HACER PARA CORREGIR O ARREGLAR EL PROBLEMA???
GRACIAS .-
GRACIAS .-
geposted Mon 01 Mar 21 @ 8:46 am
Please write in English or post in Spanish forum.
For Stems on XDJ-XZ, please read the Notes at the end of this page.. https://www.virtualdj.com/manuals/hardware/pioneer/xdjxz/layout/mixer/index.html
geposted Mon 01 Mar 21 @ 10:59 am
Let see who is the best
geposted Mon 01 Mar 21 @ 11:32 am
Pedrocasa2030 wrote I have a fully updated XDJ-XZ, just like the VIRTUAL DJ 2021.
But STEAMS only work for me when I use PADS
DOES NOT WORK WITH THE 5 KNOBS on the EQUALIZER.
WHAT CAN I DO TO CORRECT OR FIX THE PROBLEM ???
THANK YOU .-
THANK YOU .-
geposted Tue 02 Mar 21 @ 1:52 am
Should be able to use at the OUTER channels (ch3 ch4) if mixing with regular EQs at the INNER channels (ch1 ch2)
To set this see here: https://virtualdj.com/manuals/virtualdj/interface/mixer/audio/index.html#hardwareadvancedeq
geposted Tue 02 Mar 21 @ 12:51 pm
